February 18, 2021 at 9:55 pm
xiaotu
SubscriberHi,
I am trying to obtain the loss level introduced by a gold(Au) strip in a waveguide. The schemetic diagram is shown in the following.
February 22, 2021 at 9:17 pmKyle
Ansys EmployeenA very fine mesh is often required at metal/dielectric interfaces where the field amplitudes rapidly change over a short distance, so it's expected that the results won't converge until the mesh is on the order of nanometers. Have you tried reducing the mesh even further than 1 nm to see if the loss converges? It might help your testing to use metal BCs, so the only loss in the system is due to absorption in the Au and not radiation losses through the GaAs layer into the PML boundaries. You can also speed up your testing by using symmetry boundary conditions on the x min boundary, either anti-symmetric or symmetric, depending on the polarization of the mode you are interested in. Please try that and let me know if it helps.March 11, 2021 at 5:43 pmxiaotu
SubscriberHi @kjohnsonnThank you so much for your reply.nThe loss does tend to converge when I try a finer mesh less than 1nm. But I cannot reduce the mesh step less than 0.5nm, since it would report error during symbolic and numerical factorization. I think this error is caused by too many mesh points, so I tried a smaller simulation region to reduce the mesh point. However, since the simulated waveguide is a weakly guide waveguide, I don’t know how to determine the minimum simulation area that can be set to ensure reliable simulation results. Currently I reduce region to 25um*20um, and the simulated electric distribution in log scale is shown in the following figure (metal boundary is applied). Could I continue reduce the simulation region?nnIn addition, I have another question about ‘optimization and sweeps’ with metal boundary. Metal boundary will introduce a large number of nonphysical modes. So how should I set ‘Sweep’ up to obtain the dispersion of a certain mode? Thank you again.nn
March 18, 2021 at 11:07 pmKyle
Ansys EmployeeHello Array ,nSorry for the late reply. If you're running into memory problems due to the mesh, I would change the span of the mesh override regions so they are only placed where the fine mesh is required. This would be where the field is changing sharply, at the interface between the metal and the semiconductor materials. A fine mesh is not really required in the middle of the metal. Also, the mesh should be fine in the direction normal to the metal surface. The mesh does not need to be fine in the direction parallel to the interface. If you make these adjustments you should be able to make the mesh finer without requiring too much memory.nRegarding to how large the simulation region needs to be, similar to the mesh this ultimately must be determined with convergence testing. First you might want to check to see if the mode is bound, as described on this page:nArrayIf it's unbound, you will have to use PML boundary conditions for this convergence test (once you're sure the mesh issue is resolved).nTo get the dispersion of a mode you can use the FDE solver's built-in frequency sweep tool rather than a parameter sweep . This tool has an option for tracking the selected mode:n
