July 31, 2020 at 1:47 pm
kremella
AdministratorWhy does the total sum of forces acting on a system always have to be equal to zero?
July 31, 2020 at 1:48 pm
Keyur Kanade
Ansys EmployeeHi!
The total sum of forces acting on a system is equal to zero only if it is not accelerating i.e. it is in a static equilibrium. This is a consequence of the conservation of linear momentum law.
kremella
AdministratorThank you for the answer. Could you please explain what linear momentum is? And how does it lead to the condition that when a body is in static equilibrium the sum total of all forces acting on it should be zero?
Keyur Kanade
Ansys EmployeeThe linear momentum is defined as p=mv, where p is the linear momentum, m is the system mass, and v is the velocity. We can have conservation of linear momentum as long as the linear momentum stays constant in time. If you differentiate both sides of the above equation wrt time you would get dp/dt = m*dv/dt = m*a. Since dp/dt=0 for an isolated system for the momentum to be conserved, then m*a=force=0 i.e. net force on an isolated system has to be equal to 0.
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- What is the difference between internal and external flows?
- How do you define specific gravity? What is its significance???
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- Why ice floats on water
- How to gain research experience?
- Archimedes principle
- Cell Counting?
- What is the surface tension of a fluid?
- Characteristic impedance of transmission lines
- Sonic boom
613
562
220
188
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
