Why does the velocity in the center of the tank not converge?
    • thaipham0815
      I am told that this should converge, but not told how to fix it nor can I find a solution online.
      Here is the setup that I used in Ansys.
      Solver: Transient, Pressure Based
      Number of Time Steps: 6000
      Time Step Size: 0.1
      Max Iterations/Time Steps: 20
      Fluid material: Water-Liquid
      Method: Simple
      Initialization: Hybrid
      Mesh cell size: 0.001m
      Nodes: 280521
      Elements: 279017
      Boundary Conditions:
      Inlet velocity = 0.0115 m/s
      Wall = No Slip
      Outlet Gauge Pressure = 0 Pa
      Thanks for the help guys!
    • Nikhil Narale
      Can you extend the run for some more iterations? Also, can you post a snap of the residual plot here?
      If it didn't work out, try reducing the time step size. Any specific reason for solving it with transient consideration?
      Nikhil
      Is this 2d?
