why does trim feature not work as it should on space claim
    • satri
      when i trim a chord of a circle on space claim the circle center is getting shifted why does it happen.
      I am trying to trim out line 1 or 2 when i do that the centre of the circle shifts and the sector of the circle becomes a semicircle like this
      please tell me how to get stop the shift of the center
    • Aniket
    • satri
      Yes I did use trim tool in the sketch.
      I couldn't find anything useful in help that's why I posted this problem here. (I would use other design software (even though I make a model using VBA, there are some other problems which I don't want to bring it to this discussion) but I am using space claim because of it's scripting feature in python which makes my modelling process easy.
      • Aniket
        Judging by the colors of the circle and line, it appears the circle is not constrained, while the line is fully constrained in the sketch, is that right?
        I tried to duplicate the same on my end but seems to be working as expected.
        before
        after1:
        after2
        Would need some more information about your specific problem, would constraining the circle center before using the "Trim Away" tool help? One more thing I noticed is you don't have the default Grid, is that something you turned off intentionally?
        -Aniket
    • satri
      I dont know how the grid got switched off and i don't know how to switch it on.
      I thought about the constrained part that the circle may not be constrained..but when i do so ansys does not constrain it well
      see this
      the center is at 0.398mm whereas the line is at 0.4mm
      i want that 2micro meter distance between them (this is one of the reasons i stopped making the model solidworks thinking space claim will give me a better model)
    • Rahul Kumbhar
      Check the unit system of Spaceclaim. If the dimensions in sketch are very small then it may cause this problem.
    • satri
      I am in the lowest possible unit that space claim can give (mm)
      there is no option of a micron in space claim.
      is space claim limited to mm? does it not go below that?
    • Akshay Maniyar
      Hi Satri,
      As suggested by Aniket and Rahul, it looks like the issue is because of the small dimensions. You can use the micrometer as a units to draw the sketch. You have to set units before you start a new design in SpaceClaim.
      Thank you,
      Akshay Maniyar
    • satri
      I checked that it never allowed me to change the units lower than mm.
      But it worked when i started the new document. it doesn't allow you to change the value on the fly i guess.
      this fixed the problem.
      but on a separate note i was also able to fix the problem without changing the units, if i make those vertical lines with the script and still have mm as units i can trim off the outer sector without shifting the center.
      anyway changing the units of the document is a much better and cleaner solution.
      thank you
Viewing 7 reply threads
