Tagged: #fluent-#ansys, complicate-topography, viscosity, vof
December 22, 2022 at 10:38 am
Natali777898
SubscriberHello everyone,
I am trying to calculate a simple gravity VOF case (air +phase2) with the constant viscosity with the magnitude of 1e4 for the phase 2, 1 for the air. It is a 3d model(600K cells, orthogonal quality 0.4, cant make better). If my viscosity equals to 1e5 then the solution is converged, if I decrease the viscosity to 1e4, then there are 200 iterations at each time step and the solution is still not converged. I could not understand why.
I tried to decrease the relaxation parametres, tried to use differens schemes for volume of fraction equation. Could you please help me.
December 28, 2022 at 10:42 am
SRP
SubscriberHi,
1) Can you please provide more information or screenshot of geometry?
2) What is volume fraction of phase2?
3) Please share the details of vof model and model use for phase interaction?
3) How you patch phase 2 after initialization?
Thank you
January 9, 2023 at 1:09 pm
Natali777898
SubscriberHello, thank you very much for your response
Here is my computational domain. There is an inlet on the lower surface, from where phase 2 is extruded into the model domain, the outlet is the upper surface (blue), from where phase 1 exits the domain to guarantee the incompressibility condition.
phase2 is the lava Volume of fraction = 1
phase1 is the air Volume of fraction = 0
VOF model, implicite, implicite body force,Interface modelling Sharp + interfacial Anti-diffusion. I dont consider phase interaction.
I suppose that at the initial time the model domain is filled by air(phase 1), hence there is no phase 2 in the model domain.
Thank you very much for your help!
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2656
2120
1347
1118
461
