TAGGED: beams-and-shells, duplicates, mechanical, spaceclaim
February 8, 2021 at 3:27 pm
MickMack
SubscriberHi
I have developed a beam element model of a modular building. I created one module in Spaceclaim and copied it (linear pattern command), to create a structure 6 modules wide and 5 storey high, as shown in the snipper below. For some reason when i brought the model into Mechanical the floor of each module was duplicated,i.e. two copies of each floor was generated as shown in the tree menu snippet below.
I have overcome this issue by simply suppressing the extra shell elements, so the model is working, but i would like to understand how this happened.
If anyone had a similar experience i would appreciate any advice.
February 16, 2021 at 4:04 pmHuiLiu
Ansys EmployeeDoes the duplicate only show up in Mechanical, ie. no duplicate in SpaceClaim? Could you try this: 1, select all surface and beam bodies (use box selection, not selecting from the tree!), 2 Copy (ctrl C) and paste (ctrl V) to a new design, 3 transfer that new design into Mechanical and see if you still have duplicates. This will clear all the pattern relationships, and we can decide if that's what caused the duplicate.nFebruary 19, 2021 at 5:47 pmMickMack
SubscriberYes the duplication only appears in Mechanical. I have included two snippets below to demonstrate this, the first shows the surface component in Spaceclaim, and the second shows a duplicate in Mechanical.nnnI also attempted to copy and paste the model into a new spaceclaim design but it did not work and only the surfaces appeared in the new design.nn
n
March 2, 2021 at 10:43 amMickMack
Subscriberndid you ever get a chance to review the above? thanksnViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5180
3275
2453
