why i am getting mass flow contours in sections as on a single surface.
    • SACHIN17IITMADRAS
    • Karthik R
      Administrator
      Hello,nI'm moving your question to the Discuss Simulation -> Fluids for better alignment.nAlso, could you please embed the screenshot directly into your post? As Ansys employees, we are not able to download attachments from the forum.nHow are you plotting the mass flow rate contour? Could you please share a screenshot?nThank you.nKarthikn
    • SACHIN17IITMADRAS
      i am plotting contour by giving parameter as mass flown
    • Karthik R
      Administrator
      I'm sorry - but I don't completely understand your question. Could you please elaborate?nThanks.nKarthikn
    • SACHIN17IITMADRAS
      i have created an interface in ICEM CFD and similarly defined in CFX, but after getting the result when i plotted the result for the variable mass flow it showing like the image i send you. and similarly when i am calculating mass flow as variable in function calculator, it is not showing the required value because a closed surface should follow conservation of mass law.nn
    • DrAmine
      I do not understand the question: Can you report the massflow()@ the boundaries in question.n
Viewing 5 reply threads
