why I cannot patch an initial pressure for the fluid pressure
    • Shaimaa
      Can I found an answer for my problem.
      I import two parts inside the fluid module, the first one has an outlet and inlet and contain air(named as tool) .the next one is a fluid cavity(named as fluid cavity) ,I want to patch an initial value pressure of 2000pa for the fluid cavity. when i patch for the fluid cavity the fluid pressure not changes although when I patch value for the air zone the value of pressure changed.
    • DrAmine
      Is it incompressible and steady?n
    • Shaimaa
      Yesnn
      Can you check the settings in both cell zones & post these here?n
    • Shaimaa
      Hello ,nThanks a lot for your replayn Are This what you ask about.nnn
    • DrAmine
      That is per design: for incompressible flow ANSYS Fluent subtracts the reference pressure from initialized pressure field, unless you have an opening.nnDo you have an opening first?n
    • Shaimaa
      Thank a lot for your answer,DrAmine I have an inlet and outlet for the tool.nn
    • DrAmine
      So you have 2 domains one filled with air the other with water. The one for water is closed and it is incompressible. Can you just turn on unsteady solver and patch again? n
    • Shaimaa
      Thanks a lot for your support.Dr Amine,nYes , I have 2 domains one filled with air the other with water. The one for water is closed and it is in compressible.nI turn on the unsteady solver , but the main problem still found I can patch  pressure value for tool not for the fluid cavity. the pressure value for the fluid still zero although I changed its value.nIs there another condition should I set to start the fluid cavity with 2000pa.nn
    • DrAmine
      Please volume average of absolute pressure in the cavity and stop reporting Total Pressure. What does that value tell?n
    • Shaimaa
      Thanks a lot for your support.Dr Amine,nThis are the options to show the pressure .how can report average of absolute pressure in the cavity???.n
      If you have two domains that are separated by a wall, where's the wall-shadow? If they're non-conformal where's the interface bc? Please put a plane or iso-surface of mesh z-coordinate across the domain plotting pressure and also showing the mesh. n
    • Shaimaa
      Hello,nActually ,between the the two fluids there are a structural separated the two fluids .nThis structure is suppressed in the fluid module.n
      What purpose is the water region in the CFD model then? n
    • Shaimaa
      Actually ,just from one hour I knew that this fluid cavity has an inlet and outlet . So I will modify my modelnThanks a lot for you supportn
Viewing 14 reply threads
