April 7, 2022 at 8:00 am
DongwooChoi
SubscriberHello, first I want to thanks to everyone in this Forum. I got many helpful informations...
I'm doing convection cooling. I want to cooling 500K cylinder with 200K air. (Transient)
I used "Initialization" to set air temperature 200K, "patch" to set cylinder temperature 500K.
Air is contained by walls, I gave "Heat flux"=0 boundary conditions for thoese walls, so they are adiabatic.
Air and cylinder contacting walls are coupled.
April 7, 2022 at 10:36 amRob
Ansys EmployeeCheck the heat flux through the coupled wall. After 20s how much heat do you expect to be transferred, if you then look at the solid heat capacity how much should that reduce the temperature?
April 7, 2022 at 11:35 amDongwooChoi
Thank you for replying.
That was the way to think I should follow! I'll try your advice.
I don't know how to check them, but there must be some way.
Thank you very much!
April 7, 2022 at 11:48 amDongwooChoi
SubscriberThank you for replying.
That's the way to think! I'll try your advice.
Thank you
April 7, 2022 at 11:52 amDongwooChoi
I don't know why my comments are gone when I tried to edit them!
Anyway, that's how should I think about this proble! I'll try your advice
Can I get any advice about temperature gradient problem too?
Thank you very much
April 7, 2022 at 12:22 pmRob
Ansys EmployeeThe Spam filters don't like you - it'll be IP or the like so don't worry.
Re the gradient - if the heat flux is low such that there isn't enough heat to give a temperature gradient you won't see one. You're also displaying over the full range, try focussing on 495-500K and separately 200-300K.
April 7, 2022 at 1:34 pmDongwooChoi
Thank you so much. There was no one around me to ask about Ansys. I really appriciate you.
Viewing 6 reply threads- You must be logged in to reply to this topic.
2726
2156
1359
1150
462
