September 6, 2019 at 6:34 pm
wangwang
SubscriberI use Ansys version is R1, and windows 10. I drag the Mechanical APDL module into the workplace, click the icon and choose" Edit in Mechanical APDL" then, there is a error warn, I paste the information below:
*** FATAL *** CP = 1.172 TIME= 02:23:24
While 1 GPU devices have been detected on this machine, no recommended
GPU devices have been detected. Only Tesla-series or Quadro
K6000/M6000/P5000/P6000/GP100/GV100 GPU devices are recommended at
this release. For optimal performance, install a recommended GPU
device in this machine. If you wish to use an alternative GPU device,
please review the recommendations in the section titled "Requirements
for the GPU Accelerator in Mechanical APDL" in the Installation Guide
for your platform.
The above error is non-recoverable by ANSYS
ANSYS run terminated by the indicated error
Current data base saved if possible.
DATA INPUT WRITTEN ON
ansystemporary calculating filesWB_LAPTOP-58KJ4JJ6_hp_5220_2unsaved_project_filesdp0APDLANSYSfile.log
A N S Y S S T A T I S T I C S
Release: 2019 R1 Build: 19.3 Update: UP20181204 Platform: WINDOWS x64
Date Run: 09/07/2019 Time: 02:23 Process ID: 6756
Operating System: Windows 10 (Build: 17763)
Processor Model: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
Compiler: Intel(R) FORTRAN Compiler Version 17.0.4 (Build: 20170411)
Intel(R) C/C++ Compiler Version 17.0.4 (Build: 20170411)
Intel(R) Math Kernel Library Version 2017.0.3 Product Build 20170413
Above is the error information, how can I figure it out? Thank you.
September 7, 2019 at 10:18 am
September 7, 2019 at 5:58 pm
wangwang
SubscriberThank you, it works. Actually, I find your post in previous time for similar problem for other people, I followed it and successes. My past configuration is NVIDIA.
2086
1317
1108
459
