Ansys Free Student Software
Why I get the following error message each time I send to workbench the geometry from spaceclaim?
    • jccubi
    • George Karnos
      Try the following:
      Shut down all Ansys Programs.
      Browse to: %APPDATA%
      rename the Ansys directory to Ansys.old
      Try to run again.
    • jccubi
      Dear Geo
      Thanks for your kind reply but unfortunately did not work. After changing the name of the folder as you suggested, another file in the AppData/Roaming directory is created when Ansys runs again but the problem continue. Besides, after making some changes, a second problem appeared. I was able to solve the second problem but I am not sure how because I changed some options in Ansys and Space Claim configuration,
      It seems that the problem appears in the Ansys student version 2021 R.1. I installed it in another computer and the same problem appeared.
      Regards
