December 11, 2020 at 12:45 pm
HarsihilZLHZ
Subscriberif its ductile material then also most of them considers Maximum Principal Strain in EXPLICIT ANALYSIS.n -
December 12, 2020 at 11:47 am
SubscribernBecause max principal strain best represents tension, not compression, and materials most easily fail in tension.nEquivalent von-Mises strain is for both tension and compression, but material is not tearing apart in compression.n
- The topic ‘why in Explicit analysis the Maximum Principal Strain is considered for results comparison?’ is closed to new replies.
- Maximum Time Step
- Error 20211 (STR+211) while 2D impact analysis
- ls dyna has no solver
- LS-Dyna Prestressed
- Whereabouts of the LS-DYNA program manager
- License error : NO SUITABLE FEATURE FOUND
- Total Contact Force and Contact Pressure
- Contact not working in Ls-Dyna and Ls-Dyna ACT (WB)
- Element direction..
- TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid
8808
4658
3153
1680
1470
