3D Design
3D Design
Why interfaces are not showing up in spaceclaim?
    • _aryaman
      I've this as my geometry where there is a large hollow cylinder in which there are several cylindrical holes in it, with rectangular ducts.
    • Keyur Kanade
      Use split option in SpaceClaim and split the geometry of extracted fluid volume. Then you will get two faces there which can be defined as interface in fluent.
      Please go through help manual for more details
      Regards Keyur
    • _aryaman
      Actually my orignial solid is a collection of 3 solids as a result of which the extracted volume is already splitted into different parts, still there are no interfaces.
    • Keyur Kanade
      You need to split the fluid volume.
    • _aryaman
      It is already splitted.
    • Keyur Kanade
      In images I can see that there is only single body for fluid volume. Please split that body.
    • _aryaman
      Sure, I got the interfaces in Spaceclaim, but when I'm inputting the flow domain in ICEM CFD there are no interfaces coming. Could someone please tell how shall this be fixed?
    • Keyur Kanade
      There must be two surfaces at that location in ICEMCFD.
      Also make sure you are not using Share option before going to ICEM.
Viewing 7 reply threads
