Why is a species appearing in the flow without an inlet?
    • zdfrankman
      I am modeling diffusion of dissolved oxygen and liquid water across a thin membrane between two channels experiencing parallel flow.
      Each wall has zero diffusive flux, but water is appearing within the channel and oxygen is disappearing. I have run the simulation for 1000 iterations, and it appears as though this is not an aberration of low iteration number.
      What could be a cause of this non-physical appearance of a species in the channel? There are no other species other than oxygen and liquid water, and reactions are turned off.
    • RK
      May I know which version of Ansys Fluent you are using? Can you also please insert an image of the 2D model with labels describing the boundaries? Thanks!
