July 31, 2020 at 1:39 pm
Keyur Kanade
Ansys EmployeeWhy is it much easier to roll a log than drag a wood cube with the same mass?
Karthik R
AdministratorWhat is required to roll a log is the energy to overcome the rolling resistance, which involves friction energy (caused by slipping of the surface), kinetic energy of the log, and internal energy due to the deformation of the log and the road surface. For dragging a wood cube on the same surface, the energy is consumed by friction energy and the deformation of the wood. The friction between a wood cube and the ground is usually much higher than rolling friction of a wood log, thus it takes more energy to drag a wood cube than roll a wood log.
- What is the difference between internal and external flows?
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- The level of water inside the straw was higher than the level of water in the beaker
- How do you define specific gravity? What is its significance???
- Why does the total sum of forces acting on a system always have to be equal to zero?
- What is the surface tension of a fluid?
- Cell Counting?
- Explain Bernoulli’s principle
- Whats the difference between sensible heat and latent heat?
- How to gain research experience?
5290
3311
2469
