Why is my unstructured cell zone disappearing?
    • h_pigg
      I am trying to model a numerical wave tank with a moving wall and oscillating flap. I am using the layering technique for the moving wall and smoothing/remeshing for the oscillating flap. I have followed this video that is quite similar to my model (
      " rel="nofollow">
      ) but after one time step my entire unstructured zone disappears and I get a long list of errors. Has anyone else had a similar experience with disappearing cell zones? I am using Ansys 2020 R2. Thanks in advance for your responses!
      What errors are you seeing? Pictures would be helpful.
    • h_pigg
      Thank you for your reply, Rob. Here are screenshots of the errors I got and a screenshot of the mesh after the calculation stops.
      Where is the piston, and which direction is it moving in?
    • h_pigg
      The piston is the left wall and it moves back and forth using a sinusoidal UDF. The other day I was able to run the case I can't figure out what I did differently to make it work.
    • h_pigg
      I should also note that the layering zone with the moving paddle works fine on its own. It is once I add the unstructured zone that the mesh does not update properly.
      Is the unstructured zone required to move with the end of the piston?
Viewing 6 reply threads
