Why is the “Zero-Thermal-Strain Reference Temperature” that is defined in engineering data not produ
October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeThat quantity is not the reference temperature (REFT) that is used in thermal strain calculations. It is the definition temperature (DEFTEMP) used in the MPAMOD command to convert temperature-dependent SCTE data. REFT is specified in the Windows detail for each body. It is not specified in Engineering Data.
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- What is cause of error: display time for result item greater than the step end time?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
Top Contributors
2524
2066
1285
1096
459
Top Rated Tags
