March 2, 2022 at 9:32 am
Zabeeullah
SubscriberHello!
I have been doing modal analysis of a fixed beam with a point load acting at its centre. The natural frequency of the beam which i have calculated is aroung 23Hz and in ansys modal analysis it is 112Hz in bending mode. (2nd mode in modal analysis)
I am using a 170*80*4mm Rect Hollow beam of lenght 2m with both the ends fixed and a central load of 1000N acting on it. The mass of the beam per lenght is 5.45. the material is structural steel, E=210 GPA, Density=7405 kg/m^3, I=420565mm^4, y=35mm.
March 2, 2022 at 11:00 ampeteroznewman
SubscriberPlease reply with details of the hand calculation. I haven't seen a hand calculation that included a pre-stress condition, but I haven't looked for it either.
If you create a Modal analysis without the Static Structural pre-stress, what are the first and second frequencies?
Use SpaceClaim (or DesignModeler) to draw a line body and assign it the correct material and cross-section, then mesh it with beam elements. What are the first and second frequencies?
March 2, 2022 at 11:06 amSahil Sura
As numerical methods are based on result approximation, there will definitely be some deviation from the theoretical analytical methods. But this too can be minimized by considering apt boundary conditions, mesh and even theory being referred to while calculating, etc.
You might find this post helpful- Modal Analysis - Difference of Numerical and Analytical Results ÔÇö Ansys Learning Forum
Hope that helps!
Thanks Sahil.
March 7, 2022 at 6:14 amZabeeullah
SubscriberHi!
I have used the below two formules to calculate the natural frequencies of the beam. and my results were around 23Hz.
F= (1/2.pi) * (acceleration due to gravity / static deflection )^0.5
F= (1/2.pi) * (stiffness/mass)^0.5
I really dont understand where im getting it wrong.
Would really appreciate your help
Thanks Zabee.
March 7, 2022 at 6:41 amZabeeullah
SubscriberHello
Here is the link to my ansys setup:
Thanks Zabee
Viewing 4 reply threads- You must be logged in to reply to this topic.
2564
2080
1299
1106
459
