Why is there a velocity discontinuity next to a zero-velocity zone?
    • zdfrankman
      I am modeling a pair of channels separated by a zero-velocity porous zone, through which only diffusion occurs. As you can see in this image, the flow profile is not parabolic, and has a velocity discontinuity. What can I do to have a continuous parabolic flow within both independent channels? I want to have a no-slip condition on the interface.
      Here are the membrane properties that I am using:
    • Karthik R
      Administrator
      Hello:
      This question seems to be connected to your other post. Let me respond to you there. Please refrain from creating duplicate posts for the same issue.
      How do i get zero-slip boundary next to an interface? ÔÇö Ansys Learning Forum
      Please respond there and we will help you. I'm closing this post.
      Thank you.
      Karthik
