Tagged: ansys-student, fluent, fluid-dynamics, fluid-flow
March 3, 2022 at 12:05 pm
liamjones32
SubscriberI have a circular container in an enclosure and it is not draining. These are the steps I have followed:
- Transient model with g = -9.81m/s2
- VOF model with implicit body force ticked
- k-epsilon model with scalable wall functions and realizable
- water added as a phase
- operating density at 1.225kg/m3
- reference pressure location = height of cylinder within the enclosure
- Outlet at the top of the container - 'backflow volume fraction' set to 0
- 2 outlets at the bottom of the container - 'backflow volume fraction' set at 1
- Under solution methods, 'pressure' set to 'body force weighted' and 'turbulent kinetic energy' and 'turbulence dissipation rate' set to 'second order upwind'
- Hybrid initialisation and volume fraction of container set to 1 (full of water)
Please see image of set up below
Any help would be great, thanks in advance!
March 3, 2022 at 1:47 pmRob
Ansys EmployeeWhat boundary conditions are in the model? Last time you asked https://forum.ansys.com/discussion/36178/why-isnt-my-fluid-transferring-from-one-container-to-the-other#latest the two volumes weren't properly connected.
March 9, 2022 at 3:10 pmliamjones32
SubscriberHi Rob So I have set an outlet at the top of the container with backflow volume fraction set to 0 and two outlets at the bottom of the container, as shown in the second image above, with backflow volume fraction set at 1 for both.
Thanks
March 9, 2022 at 4:20 pmRob
Ansys EmployeeThe face you set as outlet in the model should be an interior. The sides of the tank should be a wall & wall:shadow pair. At the top of the tank I'd expect either an interior (open top) or wall & wall:shadow. For the latter you may find flow takes a while to sort itself out as the system will "glug".
March 9, 2022 at 4:29 pmliamjones32
SubscriberThanks I'll give this a shot
March 9, 2022 at 4:52 pmRob
Ansys EmployeeHave a look at "share topology" as that might be where you're going wrong. Note, you will need to label internal wall as such because the default boundary type will be an interior.
Viewing 5 reply threads- You must be logged in to reply to this topic.
2622
2098
1327
1110
461
