February 12, 2022 at 10:14 pm
SoftEngCHD
SubscriberI am opening a project by double-clicking on it and opening workbench. From there, I double click the solution option to open mechanical and start running simulations. Below is my workflow and some helpful information about my system.
February 14, 2022 at 9:24 pmANSYS_MMadore
Ansys EmployeePlease run this command from an elevated CMD prompt (right click on CMD Prompt and ÔÇÿrun as administrator').
regsvr32.exe jscript.dll
Once this is done, reset the ANSYS configurations by renaming the %appdata%\ansys\v###
February 14, 2022 at 10:58 pmMarch 2, 2022 at 1:38 amSoftEngCHD
SubscriberAny other solutions? Also, I am wondering if a fried/old GPU could be the issue. I have to admit that I do use this GPU for high res gaming, and considering that it I bought it 2 years ago, could the card just not be performant enough anymore?
March 2, 2022 at 6:43 pmANSYS_MMadore
Ansys EmployeeThat could certainly be an issue and you may want to try an updated graphics device for Workstations rather than a gaming device.
https://www.ansys.com/content/dam/it-solutions/platform-support/graphical-display-graphics-cards-tested-2022-r1.pdf
March 2, 2022 at 6:50 pmMangesh Bhide
Ansys EmployeeCan you please double check if under Environment variables System Variables the "Path" variable has these three entries listed before all else ?
%SYSTEMROOT%\system32
%SYSTEMROOT%
%SYSTEMROOT%\system32\Wbem
it appears that the entry in bold is either not present or not 2nd in order in the path
March 3, 2022 at 8:44 amViewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2582
2080
1311
1106
459
