Why might assembly level cut operations performed in a CAD program appear to transfer the complete u
October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeThe import of assembly level operations are not supported by most CAD Readers. If the import of assembly level operations are desired, consider using the respective CAD plug in geometry interface. Another alternative may be to export the CAD geometry to a neutral format, then import into Mechanical.
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- What is cause of error: display time for result item greater than the step end time?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
Top Contributors
2616
2098
1323
1108
461
Top Rated Tags
