March 15, 2022 at 12:28 pm
ggew
SubscriberHello everyone,
I want to mesh this model:
it is a wing with ribs inside and 2 tubes that unites them.
March 15, 2022 at 2:55 pmGovindan Nagappan
Ansys EmployeeIt appears that the tubes and ribs are surface bodies. In details of the tubes and ribs under geometry branch, you can define a thickness. Make sure you have the correct thickness value
What you are seeing is a thickness display. You can turn off thick shells/beams and you will see only the surface mesh
Make sure you enter correct thickness for surface bodies
March 15, 2022 at 3:09 pmggew
SubscriberThank you for the advice
I will check it out!
2524
2066
1279
1096
457
