May 8, 2023 at 9:30 am
BALA
SubscriberI am working on modal analysis of Assembly, i have used the solver type as program Controlled , ensured the contact also aeverything is fine. After completion of results i am gettingthe nonzero frequency in the given range but unfortunatly there are no paricipation factor data is available , What could be the reason?
in Solution information i am getting below message
" the .full file does not exist by user request. participation factor calculation will be skipped
May 9, 2023 at 10:01 am
Ashish Khemka
Ansys EmployeeHi Balaji,
Please see if the following link helps: How do You Ask for .full File When Running Ansys Mechanical? - PADT (padtinc.com)
Ashish Khemka
3311
2471
