November 10, 2021 at 2:01 pm
November 11, 2021 at 4:16 amKeyur KanadeAnsys EmployeeThe image is not clear.
In image it shows big triangles. This means it is not meshed. But at the same time it shows small triangles overlapping. So it means blade is meshed. But you have drawn both - geometry and mesh objects.
Go to outline view (right side of workflow) and right click on mesh objects and click draw. This will show you surface mesh.
Fluent Meshing Watertight Workflow:
https://www.youtube.com/watch?v=aBxbYRVoRLo
Regards Keyur
- The topic ‘Why my surface mesh look like this?’ is closed to new replies.
Trending discussions
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Fluent fails with Intel MPI protocol on 2 nodes
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script error Code: 800a000d
- Encountering Error in Heterogeneous Surface Reaction
Top Contributors
1191
513
488
225
209
Top Rated Tags
© 2024 Copyright ANSYS, Inc. All rights reserved.
