March 11, 2021 at 8:04 am
AhmadMwaheb
SubscriberMarch 11, 2021 at 1:44 pmAitor
SubscriberAssuming that you have chosen velocity-inlet boundary condition at Inlet 1, the solver only uses the value of the velocity. The problem is overspecified if you set both velocity and pressure.nMarch 11, 2021 at 1:55 pmRob
Ansys EmployeeYou're forcing a fixed amount of flow through the system. Can you double check you're running axi-symmetric over 2d and that you have enough mesh to pick up any flow features. nMarch 13, 2021 at 12:03 pmAhmadMwaheb
SubscriberAssuming that you have chosen "velocity-inlet" boundary condition at Inlet 1, the solver only uses the value of the velocity. The problem is overspecified if you set both velocity and pressure.https://forum.ansys.com/discussion/comment/110324#Comment_110324
So how can I solve the problem correctly? InMarch 13, 2021 at 5:50 pmYasserSelima
SubscriberAre you using Pressure-based solver?nMarch 13, 2021 at 5:53 pmYasserSelima
SubscriberThe resolution of your velocity vectors shows that you have very coarse mesh. Being able to select velocity and pressure at inlet, probably you are using wrong solver.nMarch 13, 2021 at 6:40 pmAhmadMwaheb
SubscriberI don't get what you mean with picking up any flow features. I'm applying 2D axissymetric. The pressure is high because he want to equalizing the pressure at the the exit of the outlet (-20) ? should I make the inlet, pressure unlet and nYou're forcing a fixed amount of flow through the system. Can you double check you're running axi-symmetric over 2d and that you have enough mesh to pick up any flow features.https://forum.ansys.com/discussion/comment/110328#Comment_110328
give a value of the velocity as a dynamic pressure?nMarch 13, 2021 at 6:40 pmAhmadMwaheb
SubscriberAre you using Pressure-based solver?https://forum.ansys.com/discussion/comment/110706#Comment_110706
yes preesure solvernMarch 13, 2021 at 6:50 pmYasserSelima
SubscriberWhere did you set the 50 Pa pressure?nMarch 14, 2021 at 7:37 amAhmadMwaheb
SubscriberAt the inlet.nMarch 14, 2021 at 8:49 amAhmadMwaheb
SubscriberSO I really need to know how to input both Velocity and pressure without making an issue? I was worng when I was putting 50 Pa as supersonic pressure.March 14, 2021 at 1:36 pmYasserSelima
SubscriberYou can not have both velocity and pressure at the same boundary unless you have supersonic flow which is not your case. Set the inlet as velocity inlet, and the outlet as pressure outlet. But you need to refine your mesh. Probably you need 5 times this number of cells with inflation at the wall to get realistic values.nViewing 11 reply threads- You must be logged in to reply to this topic.
2664
2120
1349
1130
461
