Why PRVAR does not recognize XVAR?
    • Samir Kadam
      Why PRVAR does not recognize XVAR?n
    • Aniket
      This behavior is to be expected. PRVAR always lists the variable(s) vs solution time or frequency (depending on whether it is a time based or frequency based solution). It does use the XVAR setting.nIf one is using PRVAR to post-process the results from the transient analysis that is used to calculate the response spectrum, then PRVAR should list the variables vs time.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
