Why the calculation of my 3×3 18650 series was stopped at 1200 s ?
    • Punnathorn14099
      I am simulating 3x3 18650 connected in series. I study about the maximum temperature that occur during discharge at 1 C-Rate. The problem is the calculation was stopped at 1200s. It suppose to run until 1800s and stop but it run to 1200s . Anyone has idea what am I do wrong? Please leave the comment . It will help me a lot.
    • DrAmine
      It is written in the console that User Defined Stop has been reached. So the run is stopped based on a user criterion.
    • Punnathorn14099
      Is it possible that it run out of battery? So the calculation stop.
    • DrAmine
      I don't know. There is a user defined stop: you need to check that, first.
    • Punnathorn14099
      Thanks you for your answer. I will check all parameter.
      If you're using adaptive time stepping check there - it's a common oversite as the max time is in the settings panel.
    • DrAmine
      Good luck!
    • Punnathorn14099
      I found the answer. It is about the capacity of the battery cell and C-Rate that I used.
Viewing 7 reply threads
