January 18, 2023 at 10:36 am
Mustafa Alsayed
SubscriberHallo,
I do now Hotplate. I have already the design, I wonder why the line in substrate (purple) not straight, why there is angle? Is this because of isolation?
another question, what is the degree of freedom for this design in this case, could you explain to me, how can I find the degree of freedom? -
January 18, 2023 at 10:51 pm
SubscriberAre you asking why the 54.7 degree angle is not 90 degrees? Whoever designed this part decided that was a good angle. Why do you think 90 degrees would be better?
In a Steady State Thermal analysis, the Degree of Freedom at each node is the Temperature of that node. That is what the solver is trying to compute, the temperature at each node given the loads and boundary condtions applied at various faces or bodies.
January 19, 2023 at 8:05 am
Mustafa Alsayed
Subscriberexactly I asking why the 54.7 degree angle is not 90 degrees? I know it is better but why, is it because to improve the isolation?
January 27, 2023 at 10:18 am
a_l_o
SubscriberHi Mustafa,
I looked into the matter and the line does seem straight to me. As straight as a pixel display can display straight lines...
Ok, trolling out. If the material is supposed to be monocrystalline silicon, there you have your answer: the crystal lattice is most densily packed in this direction. The angle is the inevitable result from etching processes to build up the void under your membrane because this plane is etched muched slower than others. Have a look into wafer fabrication if you are further interested in this topic. Hope I could help you out.
2066
1279
1096
457
