June 6, 2023 at 1:32 am
子溪 刘
SubscriberI directly link rhe CW laser, PD and the ele-powermeter,the optical source is 0dbm, the responsivity of PD is 1,the output ele-power should be 0dbm.But the output ele-power is 30dbm,why is it?
June 6, 2023 at 8:52 pm
Guanhui Wang
Ansys EmployeeHi 子溪 刘,
Do you mean -30 dBm? The PD output signal current, with 1 responsively, the 0 dBm (0.001 W) optical power transfers to 0.001 A current. Then the power will be I^2*R, in this case we treat R as 1 ohm, so the power is 0.001 A^2*1 ohm =1e-6 W = -30 dBm
June 7, 2023 at 8:15 am
子溪 刘
SubscriberThanks,I got it,appreciate👍
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4502
2961
1449
1322
