Why the reinforcement is not showing after importing the ACIS file from autodesk revit to Ansys DM?
    • Lina_37
      Reinforcement not showing in Ansys designer model after importing from revitnn
    • OguzhanA
      you can save. step files and import on SpaceClaim or DesignModeler. Rebars are like lines. After you have to create cross-section for rebars,Select line and select cross-section. nI hope this video will help you.
