Tagged: ansys-workbench, explicit-dynamics, mechanical, structural, workbench
March 11, 2021 at 5:51 am
Bhumik
SubscriberMarch 12, 2021 at 7:22 pmKai
Ansys EmployeeHi, did the analysis finish gracefully? Can you also show the solve.out?nMarch 17, 2021 at 5:46 amMarch 20, 2021 at 12:20 pmramgopisetti
Subscribercan you specify the number of cycles that you have used, it seems to me that you have specified only 1 cycle, can you elaborate more on this for further help, usually for the Explicit dynamics, the number of cycles are 1E7 ad by reducing the this count the solver will have significant effect as in your simulation try to increase that number to at least 1E6 in order to get consistent results so that your simulation can iterate to your desired end time. ncheers,nRamnViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1279
1096
457
