November 13, 2023 at 10:15 am
Altair45
SubscriberGood day,I'm observing the transmission along one arm consisting of the Waveguides with taper and the SIS Phase shifter.From the geometry view, it is a simple SIS structure based on the Si/SiO2/Si and just plane layers.However, there is some continuous loss in the simulation among the monitors which are positioned at every point in the xy view.Are there any points that I missed in the FDTD simulation?Here are an XY view, the cross section, and transmission data. -
November 14, 2023 at 10:01 pm
Devika
Ansys EmployeeHello, Thanks for using the forum.
Can you share a bit more deatails:
Source used, type of monitor, length and width of device.
Have you tried material fitting before running simulation?
Thanks and regards
Devika
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3155
1688
1478
