Why there is a bad display with /ESHAPE,1 command with nodes initially coincident and have different
October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeThis is a limitation of /ESHAPE and PowerGraphics. /ESHAPE,0.99 is the correct workaround. From /ESHAPE: When nodes are initially coincident and PowerGraphics is active, duplicate polygons are eliminated to conserve display time and disk space. The command may degrade the image if initially coincident nodes have different displacements. The tolerance for determining coincidence is 1E-9 times the model’s bounding box diagonal. Since the tolerance in 1e-9, you can shrink as little as /ESHAPE,0.99999999.
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- What is cause of error: display time for result item greater than the step end time?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
