June 28, 2023 at 3:12 am
Sree Ranjini
Subscriber- I am using MOTORCAD for predesign activity for converting IPM configuration with random winding to hairpin
- Keeping the same input conditions, material, rotor and stator geometry(of course with parallel slots) , same number of turns per phase for both I am observing lower back emf with hairpin
- What could be the reason for this. Does MOTORCAD takes any special consideration with hairpin winding?
June 28, 2023 at 8:47 pm
DELI
Ansys Employeehi, I will need more information, could you provide screenshots for this issue?
June 29, 2023 at 11:50 pm
Sree Ranjini
SubscriberI am using IPM machine with D shaped magnets. While adopting random winding with 16 number of turns I have back emf value as 70V. However, Keeping the same number of turns in hairpin (8 layer,4 parallel path) I observe 4% deviation in back emf keeping same magnet temperature, geometry and materials.
June 30, 2023 at 5:16 pm
DELI
Ansys Employeecan you provide pictures of the winding definition page for two winding types?
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7690
4484
2957
1435
1322
