September 7, 2022 at 2:59 pm
2019023289
SubscriberHello,
I'm studying jet impingement now. For Pressure-Velocity coupling algorithm,if I choose coupled algorithm,there is large backflow. If I choose SIMPLE algorithm ,there is no backflow at first.However, as the calculation goes on, there is backflow at last, but it is smaller than Couple algorithm.
So is it caused by algorithm, or is it a normal physics phenomenon?
Thanks
September 7, 2022 at 4:08 pm
Ansys EmployeeJets tend to entrain flow, and depending on the boundary conditions that may come from the outlet: hence backflow. I'd expect a similar result from SIMPLE and PBCS if run to full convergence, so suspect the difference will reduce with iterations.
September 8, 2022 at 1:48 am
September 8, 2022 at 8:20 am
Ansys EmployeeHave a look at the velocity field. CFD convergence isn't solely judged on the residuals, you need to check the flow field and monitors. I also suggest reading up on the back flow direction options.
September 8, 2022 at 8:42 am
DrAmine
Ansys EmployeeCan you share a picture of the geometry where we can identify the outlets?
2656
2120
1345
1118
461
