March 22, 2022 at 2:09 pm
happykiran
SubscriberMarch 22, 2022 at 8:26 pmpeteroznewman
SubscriberYes, this could be done in Static Structural.
March 23, 2022 at 5:38 amhappykiran
Subscriberthank you for the clarification I tried this problem in the static and applied joint moment instead of rotation and the problem was not solved
BC: Screw surface was a Fixed entity and applied 10N-mm joint moment.
Also, i tried applying Joint rotation of 60degrees it solved only partial load
Trending discussions
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
