September 28, 2018 at 4:35 pm
sameerfares
SubscriberHello,
i selected a wide flange section or an I-beam. i edited the dimensions.
1 where bottom flange and web meets doesn't look right as shown in red circle? is there a bug in the software?
September 28, 2018 at 6:33 pm
October 1, 2018 at 4:53 am
Keyur Kanade
Ansys EmployeeHello,
Can you please insert images for the parameters you used. As ANSYS, I am not allowed to download any attachments.
Keyur
October 1, 2018 at 4:54 am
Keyur Kanade
Ansys EmployeeAlso make sure you are using latest version R19.1.
It is available for download on this website.
Keyur
October 1, 2018 at 10:45 pm
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2620
2098
1327
1110
461
