July 11, 2019 at 2:18 pm
hsagasta
SubscriberHi,
My situation is the following one. I am working in a research to apply finite element methodology in plastic made rigid packages' structural analysys. These packages are made by a thermoforming process where a plastic made film (thickness 0,2-1 mm) is heated and formed by a mold. In this process an irregular thickness distribution packages are obtained, a deeper cavity lower thickness. Such a geometry is almost impossible to obtain with a common CAD software so nowadays I am making Static Structural analysis to packages whose thickness is regular (in reality it is not) and consequently the numerical results that I obtain are not suitable. My question is if ANSYS Polyflow is able to simulate a thermoforming process and generate a CAD 3D geometry whose thichness is irregular like a real thermofomed package??
Then, I would apply finite element static structural analysis made by ANSYS Workbench to that geometry. ANSYS Polyflow is not included in student free version so I would like to have some information before buying it.
Thank you ANSYS Comunity.
July 11, 2019 at 4:31 pm
Ansys EmployeeIf you're looking to buy software use the "Contact Us" button on ansys.com and please use the "official" email address. If you're a student your supervisor will need to put the question in: we need to talk to a University/Institute employee because the licence will be attached to the Institute. This also means we can give a full answer as export checks can be done: this is a public forum which slightly limits us.
July 15, 2019 at 1:33 pm
hsagasta
SubscriberMaybe academic license ANSYS would have a software to make similar operations. Does it have?? I only want to know if ANSYS Polyflow or some NASYS software is able to create a CAD geometry from a thickness variation result. I know that Polyflow is able to predict the thickness of a viscoelastic material piece that is thermoformed or extruded, i would like to know if this resultant geometry could be exported to other cad program or be used in another analysis inside ANSYS.
If I obtain this thickness variation solid, is ist possible to obtain a CAD geometry of it and use it in for example in ANSYS Workbench. Thank you
3744
2573
1821
1236
596
