TAGGED: -Force-calculation, 3d, 3d-anayls-s, Building, drag-force, fluid-wind
November 17, 2023 at 3:40 pm
Adam Thibodeaux
SubscriberHello Experts,
I am an engineering student and am trying to learn/use ANSYS and would appreciate any guidance you give me.
My goal is to model a 3D building to see the force distributed by wind. For example, I would like to change the wind speed for the different hurricane categories to see how it affects the force on the building. Which ANSYS software/settings would be best for this? I was thinking about using ANSYS Fluent, do you have any good articles on this type of design? Thank You!!
November 20, 2023 at 2:13 pm
Forum ModeratorYou can, and I'd use Fluent. However, with storm and higher wind speed the fluctuating component can become very significant so getting a single speed/force value may not be possible. I've run models on more common wind speeds, and I know there are articles in literature; I don't have any references to share.
November 20, 2023 at 2:16 pm
Adam Thibodeaux
SubscriberThank You Rob for your advice. I will try to look for articles in the literature space.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
