wind turbine
    • vikas1128
      can anybody tell me what is wrong in this udf code i have written for a wind turbine analysis.
      #include "udf.h"
      DEFINE_SDOF_PROPERTIES(rotor,prop,dt,time,dtime)
      prop[SDOF_MASS]= 0.122;   /*mass of body*/
      prop[SDOF_IZZ]= -0.0004307;    /*inertia moment of body in z_direction*/
      prop[SDOF_ZERO_TRANS_X]= TRUE;
      prop[SDOF_ZERO_TRANS_Y]= TRUE;
      prop[SDOF_ZERO_TRANS_Z]= TRUE;
      prop[SDOF_ZERO_ROT_X]= TRUE;
      prop[SDOF_ZERO_ROT_Y]= TRUE;
      prop[SDOF_ZERO_ROT_Z]= FALSE; /*allow rotate in z_direction*/
    • RK
      What is the error that you are getting?
    • vikas1128
      thank you, sir for your replay, actually i want to rotate a 3d fan in z axis but after uploading this code i am getting a message 6dof cant compute angular acceleration, and one more message i am getting ( no motion is detected in current time step), can you please tell me where i did wrong...
      sir , should i add moment of inertia in all direction in sdof code .....
      If you just want rotation have you looked at the sliding mesh approach?
    • amir2020
      the rotation is for wind driven n
      Yes, and you can set the rotation speed based on the blade force. n
Viewing 5 reply threads
