February 3, 2023 at 7:19 pm
Sushil Sharma
SubscriberI modeled a wind turbine blade using surface elements in space claim. I want to perform a model analysis of the edge, so I import such a model to the design modeler. While opening the model file to serve mesh to my model, some elements are not shown in the window(as shown in the attached screenshot), and some aspects are extra added to the element tree. How can I solve this issue?
February 6, 2023 at 11:46 am
Rahul Kumbhar
Ansys EmployeeCan you check the geometry in DesignModeler? Is it good?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5454
3419
2473
1310
1022
