April 8, 2023 at 4:18 pm
Tarang Joshi
SubscriberI am simulating one 3D model of my project. In that I am using translation motion to find linear velocity of an object. I have assigned band around that object.
But I am getting error "winding can not touch band".
Though my assigned band is not touching with any object.
5 mm gap is there between moving object and winding and in between that i have assigned band.
April 11, 2023 at 8:23 pm
GLUO
Ansys EmployeeHi Tarang,
Could you try adding an inner band inside the motion band to enclose all moving objects?
GL
- Maxwell, HFSS or Q3D?
- Error
5290
3311
2469
