August 24, 2023 at 6:25 am
U Abinash Patro
SubscriberI am having trouble in writing a script to create a circular window function to find power at a certain plane got using farfieldexact3d. I want the power only at the window. Please help me with some code snippet.
August 24, 2023 at 7:15 pm
Guilin Sun
Ansys EmployeeOnce you have say (x,y), you can first create 2D matrix:
X=meshgridx(x,y);
Y=meshgridy(x,y);
then create a circle:
window=ones(length(x),length(y))&((X^2+Y^2)<=RR^2);
image(x,y,window);
with given radius RR.
Please try.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7748
4504
2971
1449
1322
