July 18, 2023 at 10:21 pm
Alex Austin
SubscriberWhen I try to connect the RSMClusterConfig on Windows (v222) to RSM on Linux (v222), it's unable to connect to port 9211, but the RSM Launcher service on Linux is listening on port 9222. Seems that 9222 is the correct port for v222, so why is Windows trying to connect to 9211 (version v211?)
July 18, 2023 at 10:55 pm
VJ
Ansys EmployeeCan you share the screen shot of the full error message you are seeing?
July 18, 2023 at 11:21 pm
July 18, 2023 at 11:22 pm
July 19, 2023 at 2:47 pm
VJ
Ansys EmployeeIs Ansys and RSM ARC for 2022R2 configured in the cluster? Can you check if the RSM launcher for v222 is running on the cluster?
July 19, 2023 at 7:45 pm
Alex Austin
Subscriber$ sudo lsof -lnPp 1154
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
mono 1154 997 cwd DIR 253,0 4096 2 /
mono 1154 997 rtd DIR 253,0 4096 2 /
mono 1154 997 txt REG 253,0 30224136 5780341 /opt/ansys/v222/Tools/mono/Linux64/bin/mono
mono 1154 997 mem REG 253,0 27112 5249250 /usr/lib/x86_64-linux-gnu/libnss_dns-2.31.so
mono 1154 997 mem REG 253,0 101352 5249295 /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
mono 1154 997 mem REG 253,0 18504 5262855 /usr/lib/x86_64-linux-gnu/libnss_mdns4_minimal.so.2
mono 1154 997 mem REG 253,0 51856 5249251 /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
mono 1154 997 mem REG 253,0 122880 5783300 /opt/ansys/v222/Tools/mono/Linux64/lib/mono/gac/System.Configuration/4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
mono 1154 997 mem REG 253,0 120320 5783390 /opt/ansys/v222/Tools/mono/Linux64/lib/mono/gac/System.Runtime.Remoting/4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
mono 1154 997 mem REG 253,0 28672 5784316 /opt/ansys/v222/RSM/bin/Ans.Rsm.UPUtilities.dll
mono 1154 997 mem REG 253,0 12135712 5784163 /opt/ansys/v222/Framework/bin/Linux64/libstdc++.so.6.0.25
mono 1154 997 mem REG 253,0 5416528 5784390 /opt/ansys/v222/RSM/bin/FrameworkDependencies/libLocalization.Base.so
mono 1154 997 mem REG 253,0 98616 5784401 /opt/ansys/v222/RSM/bin/FrameworkDependencies/netstandard.dll
mono 1154 997 mem REG 253,0 136704 5784309 /opt/ansys/v222/RSM/bin/Ans.Rsm.ManagementUtilities.dll
mono 1154 997 mem REG 253,0 1087488 5783302 /opt/ansys/v222/Tools/mono/Linux64/lib/mono/gac/System.Core/4.0.0.0__b77a5c561934e089/System.Core.dll
mono 1154 997 mem REG 253,0 12800 5784366 /opt/ansys/v222/RSM/bin/FrameworkDependencies/Ans.Rsm.Localization.dll
mono 1154 997 mem REG 253,0 3175936 5783466 /opt/ansys/v222/Tools/mono/Linux64/lib/mono/gac/System.Xml/4.0.0.0__b77a5c561934e089/System.Xml.dll
mono 1154 997 mem REG 253,0 3354752 5784148 /opt/ansys/v222/Tools/mono/Linux64/lib/libmono-native.so.0.0.0
mono 1154 997 mem REG 253,0 8704 5784300 /opt/ansys/v222/RSM/bin/Ans.Rsm.ExternalLibraryWrapper.dll
mono 1154 997 mem REG 253,0 137728 5783463 /opt/ansys/v222/Tools/mono/Linux64/lib/mono/gac/System.Xml.Linq/4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
mono 1154 997 mem REG 253,0 2615296 5783468 /opt/ansys/v222/Tools/mono/Linux64/lib/mono/gac/System/4.0.0.0__b77a5c561934e089/System.dll
mono 1154 997 mem REG 253,0 20666904 5781675 /opt/ansys/v222/Tools/mono/Linux64/lib/mono/4.5/mscorlib.dll.so
mono 1154 997 mem REG 253,0 4641280 5781674 /opt/ansys/v222/Tools/mono/Linux64/lib/mono/4.5/mscorlib.dll
mono 1154 997 mem REG 253,0 85504 5784301 /opt/ansys/v222/RSM/bin/Ans.Rsm.GeneralUtilities.dll
mono 1154 997 mem REG 253,0 450048 5784318 /opt/ansys/v222/RSM/bin/Ans.Rsm.Utilities.dll
mono 1154 997 mem REG 253,0 47616 5783408 /opt/ansys/v222/Tools/mono/Linux64/lib/mono/gac/System.ServiceProcess/4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
mono 1154 997 mem REG 253,0 2029592 5249106 /usr/lib/x86_64-linux-gnu/libc-2.31.so
mono 1154 997 mem REG 253,0 825504 5784137 /opt/ansys/v222/Tools/mono/Linux64/lib/libgcc_s.so.1
mono 1154 997 mem REG 253,0 157224 5249290 /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
mono 1154 997 mem REG 253,0 18848 5249124 /usr/lib/x86_64-linux-gnu/libdl-2.31.so
mono 1154 997 mem REG 253,0 35960 5249297 /usr/lib/x86_64-linux-gnu/librt-2.31.so
mono 1154 997 mem REG 253,0 1369384 5249221 /usr/lib/x86_64-linux-gnu/libm-2.31.so
mono 1154 997 mem REG 253,0 14848 5784307 /opt/ansys/v222/RSM/bin/Ans.Rsm.Launcher.exe
mono 1154 997 mem REG 253,0 104768 5807910 /opt/ansys/v222/Framework/bin/Linux64/libz.so.1.2.11
mono 1154 997 mem REG 253,0 191504 5249065 /usr/lib/x86_64-linux-gnu/ld-2.31.so
mono 1154 997 mem REG 0,26 4096 4 /dev/shm/mono.1154
mono 1154 997 0r CHR 1,3 0t0 5 /dev/null
mono 1154 997 1w REG 253,0 72 5898413 /tmp/rsmlauncher222.w5qlKkrikB.log
mono 1154 997 2w REG 253,0 72 5898413 /tmp/rsmlauncher222.w5qlKkrikB.log
mono 1154 997 3r CHR 1,9 0t0 10 /dev/urandom
mono 1154 997 4u REG 253,0 913 5898420 /tmp/rsmlauncher222-2023-07-18-17-55-19.log
mono 1154 997 5u IPv4 54507 0t0 TCP *:9222 (LISTEN)
mono 1154 997 6u IPv4 30067 0t0 TCP 127.0.0.1:9222->127.0.0.1:35696 (ESTABLISHED)
mono 1154 997 7u IPv4 54510 0t0 TCP 127.0.0.1:35696->127.0.0.1:9222 (ESTABLISHED) -
July 19, 2023 at 7:47 pm
Alex Austin
SubscriberSo, yes. RSM Launcher is running, and listening on port 9222. Why is ClusterConfig, on Windows, trying to connect to port 9211?
July 19, 2023 at 8:50 pm
VJ
Ansys EmployeeThanks for confirming. Have you changed anything in the rsm config file for 222?
Go to the
/v222/rsm/config and vi Ans.Rsm.AppSettings.config Search for the keyword "LauncherService"
Under this, check for "Port" value. it should be set to 9222.
July 21, 2023 at 5:49 am
Alex Austin
SubscriberDouble-checked that file; yes Port is still 9222. You can see in the lsof command above, that the launcher is listening on port 9222. Windows ClusterConfig still seems to be trying to connect to 9211. Why might that be the case? It's definitely v222.
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7742
4502
2967
1449
1322
