August 7, 2019 at 5:00 am
shahzaibilyas
SubscriberHi,
I am doing a project on analyzing the wing flutter speed using ANSYS 2 way FSI. I have created the wing and the domain. First I have done the modal anaysis to analyze the mode shapes and frequencies. Then I buildup tranisent strucutral and fluent setups and couple them with system coupling. When I run the system coupling, everything works correctly.
But the problem I am facing currently is that i dont know how to proceed further means how to determine the flutter speed? Where should I be able to know that flutter condition has reached? If anyone has the solution, then please tell me?
Regards
Shahzaib Ilyas
2066
1279
1096
457
