Wired stent doesn’t appear in my results
    • yann
      I've modelized a stent (wired body) surrounded by an aortic membrane (volumic body).
    • Ashish Khemka
      Is the stent a rigid body or fixed? You can model a stent as a volumic body and then define the contact between the stent and membrane. You can deploy symmetry as well. Please see if the following course helps you further:
      Cardiovascular Stent Simulation| Ansys Innovation Courses
      Regards Ashish Khemka
    • yann
      Hi, the stent is a rigid body. I've prefered to modelize it as a wired body beacause it needs less nodes and elements.
      I've found the solution if it can helps. In "Solution" - "post-treatment"-"beam section results" is "No" by default so it needs to be switch by "Yes".
    • yann
      However the contact force reaction doesn't work, I don't know why
Viewing 3 reply threads
