Wireless power transmission resonance frequency
    • Rakan
      Hi
      using twin builder i made W.P.T system with
      c1=c2=29Pf
      L1=L2=972nH
      K=0.587
      Rin = 300 ohm and RL= 1000 ohm
      so resonance should occur at 30MHZ and so maximum power but as you can see it does not , the problem is as i change Rin the maximum power frequency changes and get to 30Mhz only when i change it to 24ohm ? should it not be that the resonance and maximum power frequency independent from Rin ?
      thank you for your time
Viewing 0 reply threads
