November 28, 2022 at 7:30 pm
valentin miguel
SubscriberHello,
I am working on Wizard for SpaceClape with ATC Builder.
I like to use the function " Measure Helper" but I fail.
I use it for 2 different missions.
A first for finding "X overall".It's important to know, for instance, function "xOverall = MeasureHelper. BodyExtrema (selection). X" works perfectly in scripting in SpaceClaim but return an error in wizard Script.
I have one error, I am looking, but don't find a solution.I have created a little script for tests of the solution if you have one.
Python code, name is "main.py" :import Systemimport clrimport sysimport osimport mathimport zipimportimport __builtin__import commandsimport random"""'SpaceClaim':, , 'Commands':, 'System':, """clr.AddReference("SpaceClaim.Api.V22")clr.AddReference("SpaceClaim.Api.V22.Scripting")#clr.AddReference("AnsysSCPlugin.22.2")#from SpaceClaim.Api.V22 import Geometry#from SpaceClaim.Api.V22.Scripting import Commands,Helpers,Selection#from AnsysSCPlugin import *from SpaceClaim.Api.V22 import *from SpaceClaim.Api.V22.Scripting import *from System import *part = Nonedef oninit(context):returndef GenerateBF(step):global partwin = Window.ActiveWindowcontext = win.ActiveContextpart = context.ActivePartif part==None:win = Window.ActiveWindowcontext = win.ActiveContextpart = context.ActivePart.Masterbody = part.Bodies#verifier le measurehelper#---------les selection--------------ExtAPI.Log.WriteWarning("TENTATIVE 2")#body = GetRootPart().Bodies[0]#se = Selection.Create(body)#se = Selection.Create(GetRootPart().Bodies[0])#se = PowerSelection.Bodies.AllSolidBodies(PowerSelectOptions(False))#se = Selection.SelectAll()#se = SpaceClaim.Api.V22.Scripting.Selection.ISelection.FilterByVisible#---------------------------------- strat 1#X = Direction.DirX#Y = Direction.DirY#Z = Direction.DirZ#XMIN = se.GetExtremePoint(-X,Y,Z)#XMAX =se.GetExtremePoint(X,Y,Z)#YMIN = se.GetExtremePoint(-Y,Z,X)#YMAX =se.GetExtremePoint(Y,Z,X)#ZMIN = se.GetExtremePoint(-Z,X,Y)#ZMAX =se.GetExtremePoint(Z,X,Y)#xOverall = abs(XMAX[0]-XMIN[0])#yOverall = abs(YMAX[1]-YMIN[1])#zOverall = abs(ZMAX[2]-ZMIN[2])#----------------------------------- strat 2#bb = Selection.Create(GetRootPart().Bodies[0])#MAX = bb.BoundingBox.MaxCorner##MIN = bb.BoundingBox.MinCorner#xOverall = abs(MAX[0]-MIN[0])#yOverall = abs(MAX[1]-MIN[1])#zOverall = abs(MAX[2]-MIN[2])#-------------------------------------strat 3#centre = SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper.GetCenterOfMass(se)#rX = Direction.DirX#ms = MeasureHelper.BodyExtrema(se).X#bb = SpaceClaim.Api.V22.Scripting.Selection.ISelection.AddToActive(Selection.Create(GetRootPart().Bodies[0]))#rr = SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper()#cvd=rr.BodyExtrema(bb)selection = SpaceClaim.Api.V22.Scripting.Selection.BodySelection.Create(GetRootPart().Bodies[0])xOverall = SpaceClaim.Api.V22.Scripting.Helpers.MeasureHelper.BodyExtrema(selection).X#sele = PartSelection.Create(GetRootPart())#sele = GetRootPart().Bodies[0]part = NoneError is :Error when invoking function 'GenerateBF'.
Traceback (most recent call last):
File "D:\stage - Copie\BBS\1213\BBS\main.py", line 87, in GenerateBF
StandardError: Exception has been thrown by the target of an invocation.
TypeError: expected IDesignBody, got DesignBodyIf you can help me, thanks -
December 6, 2022 at 1:26 pm
Aniket
Ansys Employee-
December 6, 2022 at 3:06 pm
valentin miguel
SubscriberHi,
thanks for your time, error comes from the complete code, the lines are not good.
Here is the error.
File "F:\stage - Copie\BBS\0612\BBS\main.py", line 399, in GenerateBF
File "F:\stage - Copie\BBS\0612\BBS\main.py", line 120, in CreateDie
File "F:\stage - Copie\BBS\0612\BBS\main.py", line 106, in takedim
AttributeError: 'type' object has no attribute 'BodyExtrema'
December 7, 2022 at 11:44 am
Aniket
Ansys Employee-
December 7, 2022 at 4:17 pm
valentin miguel
SubscriberCode lign 106 is :
xOverall = MeasureHelper.BodyExtrema(se).Xlines of code 399, 120 call the "takedim" function which contains the error.And error is :Error when invoking function 'GenerateBF'.
AttributeError: 'type' object has no attribute 'BodyExtrema'-Miguel
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2564
2080
1299
1106
459
