March 24, 2023 at 5:55 am
March 24, 2023 at 10:22 am
Aniket
Ansys Employee-
March 24, 2023 at 10:51 am
March 24, 2023 at 2:12 pm
Mike Rife
Ansys EmployeeHi Raheem
This could be caused by a few things - so let's start at the beginning and check the installation log for errors [C:\Program Files\ANSYS Inc\install.log and install.err] .
Mike
March 24, 2023 at 2:21 pm
March 24, 2023 at 4:37 pm
Mike Rife
Ansys EmployeeRaheem
Ok - that is a generic error code. What did you use to extract the installation files? If you used MS File Explorer built-in please instead use a 64 bit compression utility like WinRar or 7Zip. Did you right-click the setup.exe and chose to run as the admin? If not please do so. Does the system have enough space available on the C drive?
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
5162
3267
2443
